Alexis
I' am currently fitting out a 6ton (metric) 34 feet bluewater yacht.
To keep the foredeck as clear as possible, I am thinking of installing a vertical electric anchor windlass, above deck (motor below), on the starboard side, against the "gunwale", directly abaft the anchor well. By installing it in this position, the lead to the bow-roller isn't correct, so I'd have another roller, mounted on a vertical axis, just abaft the bow roller.
The goal is to have a clear foredeck, to be able to have the area totaly secue (the chain between windlass and roller would run in some sort of covered gutter) and this position enables me to secure the windlass very strongly (side of hull, deck and forward structural bulkhead.
(If this isn't clear, I cam PM you a sketch of the set up)
My questions:
Has anyone seen or experimented such a layout ?
What do you lot, used to anchoring, think of this system ?
Many thanks,
Alexis (Sorry lads, in this case, Alexis isn't a lass, and whats more, he's married)
My questions:
Many thanks,
