antaris
Here it is:
It is quiet and rotates fine - and I just checked the Voltage on the 2-core cable that comes down the mast: anything from 5v all the way up to 20v, on a windy day (10-20knots, variable).
It was connected directly to my batteries. Is that a good setup? Surely 20V is not good (albeit with veeery low A). Should I connect it to some sort of controller?
Next year, I plan to connect a solar panel and controller - so (since it is there already) can I also connect this to the same controller - and maybe buy the solar panels next year? I thought, since it is there and seems operational, to use it as trickle charger. Not going up there to remove and ditch - as yet.
PS Pretty low amperage, really, but in Aegean winds are pretty often in the 20-35 knots range.
