Venus for navigation
Bobc
20 Jan 2011
Did once for a channel crossing when all the instuments went down on a mate's boat, and with it being steel, it didn't have a magnetic steering compass.
Snowgoose-1
2 Jun 2015
Yeah. It's so bright it's an easy target.
Occasionally one horizon lit up by a big moon, got two position lines. Venus and moon lower limb.
Would imagine the pros on here know more though.
Yes. In the lightness hit parade it is number three after the sun and moon. Got to be handy somehow or other
[194224]
11 Oct 2022
Of the navigational planets it's the brightest of course but other than that it has nothing to set it apart from the other three in terms of its use for navigation.
[194224]
11 Oct 2022
Polaris is not one of my favourites at all. It is so dim. Ursa Major on its own is little use either as the three navigational stars within it offer precious little angular separation.
Frank Holden
23 Nov 2009
Cruising in the Golfo Corcovado
I can never find Polaris....
Venus? Yes , in the day job along with stars at twilight, a few additional but simple corrections required.
'Venus on the meridian' once or twice just because I could. Fairly simple to pre compute.
I have I think only once ever used the moon, horrible thing, far too many corrections to be a pleasant experience when there are simpler options.
Sirius and Canopus were usually in the mix of stars, along with one in Orion and another in the Southern Cross.
[194224]
11 Oct 2022
I am largely in agreement with you Frank although one advantage of the moon is that it is often visible during the day with the sun and when both are at a reasonable altitude and separated can give an opportunity for a fix rather than just a single PL. I quite like the moon sight reduction though but the problem I find is that being so close to earth it moves so (relatively!) fast and taking an altitude with any confidence is tricky.
Frank Holden
23 Nov 2009
Yes, that makes sense but I never sailed with anyone that used the moon. Unfamiliarity with the corrections maybe? Sloth? Dunno.
Buck Turgidson
10 Apr 2012
Zürich
I know an RAF crew who when their aircraft was first fitted with a FLIR system spent some time avoiding what the navigator thought was a barrage ballon but which turned out to be the moon! Nav bought the beers after landing :)
capnsensible
15 Mar 2007
Atlantic
I've had several crew wake me mid ocean to report the sighting of a vessel. A quiet sit in the cockpit chatting about what lights vessels carry and how it doesn't include a large rock lit by the sun got the message over as the moon cotinues its urgent passage across the sky. Important to do it nicely though coz next time they might not shake you for a super tanker....
Frank Holden
23 Nov 2009
Passes the time on watch on a small piece of plastic bobbing around on the Mighty Deep.
What surprises me - looking back - is how many 'professional navigators' knew as much as they had needed to pass their tickets and no more. It was reflected in their approach to the job. Great was the fear of having to calculate a Great Circle distance and initial course which I found to be a lot easier than a full blown mercator sailing calc.
capnsensible
15 Mar 2007
Atlantic
Something the small yacht sailor is happily relieved of as Neptune sends us the vagaries of the wind!
