freedom44
I recently read again Eric Hiscock’s “Cruising under Sail” which is a delight.
I was intrigued by his explanation how ventilation occurs in a boat. He explained that if a forehatch which opened facing aft was left partially open that it would suck air from the boat and through the open companionway and cause it to exit from the forehatch.
As many hatches are capable of being changed from forward to backward facing, is it still better to set them up as above, or is it better to design them as “common sense” would dictate ie opening facing forward so as to scoop as much fresh air into the boat.
As many boats now have considerably more hatches than in his day when typically there was just a forehatch and companionway, does his suggested practice fall down when you have, say, a large main cabin hatch?
I appreciate the benefit of aft facing hatch from the perspective of spray not getting below. I am just interested in the ventilation aspect.
I look forward to your opinions
