stu9000
I have fitted a force 4 electric head
Force 4 Electric Sea Toilet 12V | Force 4 Chandlery
It replaces the standard push pull jabasco pump which was pretty old and very calcified in the bottom section.
It certainly isn't silent flush but isn't particularly intrusive. And the previous manual banging as the manual pump hit the end of its travel certainly was intrusive. I'm hoping that a button press will ensure a thorough flushing by users.
The existing set up has a vented loop on both the water in loop and the wider black water outlet hose.
I understand the value of avoiding having seawater siphon into the boat but is it required on the water in side?
The bowl is cited slightly below sea level but doesn't the electric pump prevent siphoning?
I would leave well alone but the pump has to run for several seconds to pull water over the venting loop. Not having a vent would meant the pump would prime more quickly.
This website seems to suggest a vent is not required on the water in side.
Y-Valves / Vented Loops / Check Valves -etc. - Vented Loop Q&A - Marine Sanitation & Supply
I'm also curious about the nut at the top of the loop. It seems to twist open and closed but air vents regardless.
Thoughts?
S
Thoughts?
S
