STATUE
I have bulkheads that are tired, scruffy, scratched.
One answer would be to veneer over it, most of it is verticle.
How to do it ?
How to do it ?
Depends whether the original finish was a veneer. Very easy to sand through veneer and make a bad job a great deal worse!Are they good enough to sand back and re varnish ?
I have used iron-on in piano restoration with great success. But it can also be glued if you prefer as the backing doesn't activate without the heat. The glue advertised on Pandos link is excellent for this job.Pandos, How well do self adhesive veneers stick to bare sanded wood or, don't they? I've found the heated (iron-on) adhesive films used with paperback veneers were quick to come unstuck from bare surfaces. G.
An easier solution is a 3mm sheet of veneered faced marine ply... Glued onto the bad bulkheads... Easy depending on your skills....
