Ian_Edwards
I've done quite a lot of veneering before, but it has always been re-veneering existing panels or locker doors.
This job is veneering a new , or should I say replacement panel, so I'm starting with a sheet of plywood.
Is it better to cut the plywood to size and then veneer it, or veneer an oversized bit of ply and then cut to size, or doesn't it make any difference?
In previous work, I've always over sized the veneer, then trimmed with a very sharp craft knife, by laying the panel veneer face down on a flat surface and using the edge of the panel as a guide.
However, the unsupported edge of veneer is vulnerable , and I have been known to knock it and chip the veneer.
From that point of view it seem better to veneer the ply, then cut it to size, but then there is the risk of chipping the edge of the veneer when cutting to size.
Which way around would a time served cabinet maker apply veneer?
