superheat6k
One of the original 80mm VDO tachos on Boadicea has been replaced with a smaller 52mm, also VDO.
At Netley Boat Jumble I picked up for a few quid a new in box and unused VDO 80mm tacho, but the connections are different.
The older smaller 52mm tacho has: 1 - no connector; 2 (W to Alternator pickup); + ; -
The newer 80mm tacho has: 1; 2 - no connector; + ; -
I tried connecting it with the alternator feed to terminal 1 but nothing happens.
VDO website simply says terminal 1 is not assigned but this tacho does not have a terminal 2 (or W).
There is also a selector switch, but I assume this is to set the pulse count to match the scaling.
Any ideas, or should I return it next boat jumble ?
Voltages for both are multi 9 - 32v.
