Varnish overcoating epoxy
weaver_fish
10 Aug 2005
Any recommendations based on experience for the best two pack (I presume) varnish to use to overcoat a west-system epoxied wooden tiller?
Cheers
Some years ago i built a coldmoulded Whitehall rowing boat, i finished her with SP systems Spacoat which is supposed to be more UV resistant than standard epoxy, it was then covered with two pack polyurethane varnish. Magnificent finish but it chipped easily as it was glass hard with no flexibility. It lasted 3 years and started to crack up, in the end i had to strip it of which was an absolute pig and start again with Epifanes oil based varnish. this outlasted the epoxy 2 pack by years and was far easier to maintain.
Standard West epoxy has virtually no UV resistance and will go gingery quite quickly even if covered with 2 pack.
I would not use 2 pack again if you paid me!
I would second Epifanes, or I have had a beautiful finish on sidedecks on a dingy with Schooner varnish which is (if I remember rightly) Blake's tun-oil varnish over epoxy.
If its fully epoxy sealed I would consider Perfection 2 pack, otherwise any decent yacht varnish. Either way, if its a decent piece of work I'd make a canvas cover to keep the sun off it.
Funnily enough, I was reading a book on woodstrip canoe construction last night. The hulls are epoxy coated and then varnished. The writer recommended a spar varnish (tung oil based) with UV filtering properties to protect the epoxy. A two pack polyurethane with similar UV properties came second as it was more difficult to maintain. Single pack polyurethanes were on his banned list!
Epoxy is brittle and would probably not be good for a tiller as the tiller will flex. I agree with the recommendations for Epifanes but I would also add that you take the tiller home and varnish in warm conditions and allow to cure for some time before you fit it to the boat. I find that this gives a tougher and longer lasting finish.
There you are then. I didn't remember correctly /forums/images/graemlins/grin.gif
A lovely finish and very easy to apply. Just takes about 2/3 weeks to harden properly.
Epoxy should be fine as a coating. It's only when you introduce a glass mat that it gets touchy about movement, but a coating soaks into the wood and leaves a hard surface (which is a bugger to flat down) and the varnish sticks to it like......well, you know.
Only problem I found with traditional varnish is that it sinks as it hardens, so ideally flat between coats. On the other hand it needs less coats over epoxy than on plain wood. (UV considerations apart)
