venntim
Active Member
I recently repaired a broken cabinet on my boat and took the opportunity to strip the old varnish in order to refinish the it. I was surprised however, that the varnish doens't seem to dry (it is left sticky) on the areas with exposed (105/205) epoxy. The varnish I used was International Goldspar Satin in a 50/50 turpentine mixture. Guess I should have researched first. Afterwards I read from West's site that you should use 207 Special Clear Hardener if you are planning to varnish... And varnish with two-pack...
What are your thoughts? Should I sand the varnish away and apply a layer of 105/207 and then varnish with two-pack?
Oh boy.
Oh boy.
