Dave99
Even if its Coat over dry, I always do a light sand just to so you can see where you have been. To fix the brush marks now you'll just have to sand back to a smooth surface. Add some thinners and don't go over bits you have already been over afterwards. Work it in locally then move on to the next bit, but if you have a 'holiday' (but where there's varnish not thick enough) don't go back because it will turn into a mess - just fix it once you add more coats. For bare wood you should aim for 7-10 coats maybe.
