Kinsale373
Youre correct Rogershaw! Its obviously too early in the morning for calculations for me ! I,d stay away from adding controls or transformers anyway when there is no need.
Kinsale 373
Kinsale 373
That would suggest 1/4 of the power.You are wrong
The element is a resistor and the resistance stays the same I (current ) = V(oltage) / R(istance) so as the voltage reduces the current will decrease and W = V * I so the if the current halves the wattage will be half
The element is unlikely to be a very good resistor, I'd expect it to run quite hot at 230V and increase its resistance significantly.
So, I'd expect the current to drop by less than half, and the power to be maybe 1/3?
A water heating Eberspacher is a good answer IMHO.
Yes you are correct as in theory both the voltage and current will be half, so an adjustable supply would be the best.
Gas is file but if you can heat water with engine heat which is free.
In my case the shore power electricity is included in my mooring fees so again no additional cost unlike gas
The item I linked to in post 18 is 'infinitely ' adjustable. Apparently it skips varying number of cycles in the 50Hz AC input, thus reducing power demand. I don't pretend to fully understand this explanation so I stand to be corrected.
If you click on the datasheet linked i nthe RS item, you will see mention of controlling the conduction phase angle from 30 to 160 degrees. It sounds very much like the Triac circuit as Roger suggested....
I am looking at exactly the same challenge. Could I ask how you implemented the linear voltage regulator?In case others come across this thread, Bristoljim kindly pointed me in the direction of this which seems to do exactly what I want.
United Automation CSR2-10E Linear Voltage, Voltage Regulator 10A, 230 V 3-Pin | RS
