Fr J Hackett
When I'm surveying Vancouvers, it's nice to know as much as possible about their history.
Yours is the second one that I have been assured is the first V34 produced.
I sold it about 7 years ago if I had to guess somehow 64 rings a bell but I can definitely assure you that she was the first V34 built and Kevins V32 Islander 2 was the last V32 built and they were built alongside of each other. The first couple of V34s had cast iron keels ( eventually replaced with lead and the weight moved a little forward) and tended to drag the stern under power I and others used some lead in the forepeak to counter that so if you see it that's the reason. One thing many of the Vancouvers suffered from was the compound used to fill the hull to deck joint, it often contained voids went hard and cracked. Water got under the caprail and travelled along and eventually appeared. Those leaks were impossible to trace until you lifted the caprails and renewed the filler, I can't remember what I used but a boat builder advised me.
