Valve - Avon Redcrest inflatable floor
Chi34
21 Oct 2010
Can anyone help identify this valve or suggest an alternative?
It's from 1998. The floor has started to deflate.
I have tried Leafield, who made it, and Ribstore. No good so far.
The floor is quite thin, so most modern valves look too deep.
Although the Redcrest tubes are Hypalon, the floor seems to be PVC.
Finally, there is a 90mm circular patch on the underside, opposite the valve, with a serial stamped on it.
I wonder if this acts as reinforcement or if it covers access to the rear of the valve for a repair?
Anybody been here before?
Robert
Ribtecer
23 Aug 2006
Blimey, that was easy and works a treat.
My valves are the "B7" variety, I just dropped a few drops down the valve and spread it about with a small flat blade screwdriver. Then I pumped it up and its kept its pressure for 24 hours.
Thanks all.
