scubaman
Just picking up on Omegas suggestion regarding fitting an electric pump. I suppose i could be installed 'parallel' (as in t-joint + pump + another t-joint, you get the idea) on the intake side so that when it operates, it forces more water through the box. It could possibly even be triggered to operate off the overheat sensor, or a secondary sensor to allow it to trigger before the overheat.
A bit complex solution to a simple problem but I'm thinking that playing with the scoops is not without it's potential issues either.
