Usual Battery Charging Setup
Fire99
11 Oct 2001
Bangor NI
Hi all,
This has possibly been covered many times and I'm doing a lot of research on the topic but to help things along a bit, can someone explain the likely charging setup on a twin diesel engine mobo with house and start batteries + a bridge solenoid?
Reason I ask is that my battery setup has been on my list of to-do's to investigate as reading some email correspondence from a previous owner, the house and starter batteries have been bridged as one.
My Cat's run 115amp alternators each and I have Stirling battery charger, along with a Onan generator with its own starter battery.
Is there a 'usual' configuration for charging from the dual alternators and how would the charge be split between the starter and house batteries??
As I say this is a winter project for me. I did electrical engineering as a young guy so I have some experience but boats can be a bit of a pick n mix of ideas so any information would be helpful.
cheers,
Nick
Could be any one of several systems Nick, especially if previous owners have been tinkering. If the house and engine batteries have been bridged that's a definite no-no.
The mains charger could be a multiple output version, charging all batteries.
The generator is likely powering the mains charger ?
Engine charging could be split by diodes, one engine charging domestics and one engine batteries, or using a VSR.
Best bet would be to investigate what each bank of batteries do and how the various charging sources are connected and then make any necessary changes.
Thanks a lot Paul. I have a sniffy thought that that is exactly what they've done due to probably a slightly lazy starter motor that happens to live in an awkward (ish) place to remove.. Lazy mechanic-ing is on my mind. Crazy that this appears to have been done when the boat was just 6 years old!!
The clue was when I turned the engine DC isolator off and there was still 12v at the engines..
The mains charger (Stirling) is a multiple output charger so we're on the right scent there..
I'll do some digging. :cool:
