Greg2
We sometimes run our Broom 41 on one engine on the river. Whilst she has a planing hull there is also a small skeg keel to help with keeping her straight. I find that dropping one trim tab and with around ten to fifteen degrees of helm she tracks straight and can alter course etc easily. The gearboxes allow this as they have sufficient oil circulation when the engine isn't running and were probably chosen by Broom for that reason.
We do this for a couple of reasons. Firstly to work one engine a little harder, which is probably better for it and secondly to effectively halve the engine hours we would be adding when doing slow passages inland.
Our steering system is independent and doesn't require an engine to be running and by running half an hour at a time on each engine we avoid the cutlass bearings getting too warm (water cooled from the engine where they go through the hull) and we share the battery charging. It also helps with keeping to river speed limits.
