snooks
Definitely not iNavX if you want to use it to route plan. The distance measuring ruler is quite useless and impossible to use for amy practical purpose.
Not sure what your problem with the ruler is...
Double tap on the chart, then drag the dot which will turn red and will expand into a line with co ordinates, bearing and range to the red dot. Green dot is the start, red is the stop.
Quite useless? Impossible to use? Really? I picked it up within 3 minutes of playing when I haven't used it for years...as long as you are at the right scale to begin with it's simple..Are you sure it's not operator error???
