Using Adhesives to fit deck organisers
if they hold the hull and decks together for sunseeker im pretty sure they will hold
The effectiveness of any adhesive increases with the surface area of the bond. A hull to deck joint has a much greater surface area than a clutch - especially if the hull to deck joint was designed with adhesives in mind and thus has mating flanges.
The other surface area problem is that a large backing plate spreads the load on the GRP over a larger area than the fitting. How do you do that with a glued on fitting? The danger is that when a big shock load is applied, if the adhesive does works really well, then the GRP will fail and you will end up with a hole in the deck.
I agree with Gardenshed. Use bolts backed up over a goodly area.
