Used anodes
mdonnelly
14 Dec 2003
Bangor Co.Down
Have just replaced hull and saildrive anodes. The saildrive anode is 60% gone and the hull anode 25% gone. Any suggestions as to what to do with them? Am loathe to bin them.
sarabande
6 May 2005
some crafty type (i.e. craft - skilled) will be melting them down and casting them into new ones....:)
stuartwineberg
24 Oct 2007
Romsey, Hants
Careful
I am sure I won't be the only forumite to remind you that smelting zinc is extremely dangerous - the vapour is very toxic - as Blue Peter says - don't try this one at home. I take them down to the local scrap yard and weigh them in. Not sure of the current price but non ferrous scrap is worth a few bob.
electrosys
23 May 2009
Boston - gateway to the North Sea (and bugger all
I am sure I won't be the only forumite to remind you that smelting zinc is extremely dangerous - the vapour is very toxic ...
An exaggeration. So-called 'metal fume fever', caused by breathing-in large quantities of Zinc Oxide dust (not vapour: metallic zinc doesn't exist as a vapour - it's far too reactive) is a transient condition with flu-like symptoms. Typically 24hrs. Unlike lead poisoning, it seldom has any long-term ill effects.
You'll find Zinc Oxide in ElastoPlast, and in more creams and ointments than I'd care to shake a stick at - from which of course the skin actually absorbs the Zinc Oxide.
The UK current regulatory limit for Zinc in water is 5 mg/L
A total daily Zinc intake of up to 50 mg/day is considered safe.
doug748
1 Oct 2002
UK. South West.
Throw one in with your anchor chain.
Electroplating small items with zinc is quite easy, using everday chemicals. Handy if you have a ald motor bike or car.
VicS
13 Jul 2002
I seem to through anode studs more than anodes!! But make my own now, which seem to last longer!
The anode ought to protect the studs extremely well. Your experience suggests a poor contact between the anode and the studs ... too much sealant ?? .. with the result that the studs are acting as the anode .
It is possible to get stainless steel studs for anodes.
VicS
13 Jul 2002
Vic, if you use SS studs, won't they corrode the thing they are supposed to protect in a case like this?
I'm just pointing out they exist and in fact MG Duff supply them.
I think the stainless may lose the protective oxide so its position in the galvanic series changes to be much closer to mild steel than when passive. Its is then protected by the anode in the same way that mild steel would be. A bit more of a potential difference still between it and zinc but maybe the advantages off set the disadvantages
I guess the attraction is that when out of the water it wont suffer from the surface rusting that mild steel studs will. That might be worth considering for a boat on a drying mooring if there is a problem with the standard zinc plated mild steel studs.
Not presenting any of this as fact ... just thinking aloud.
GrahamHR
12 Nov 2009
Cheshire
I've had stainless steel anode studs (actually nuts and bolts) on my trim tabs for 7 seasons. I also use stainless bots to attach the anodes to the captive bolts. I don't even think they're A4, more likely A2. Anode erosion is nothing out of the ordinary and the tabs and bolts are still there.
