JOHNPEET
Just wondering if any other of the Forumites have had similar un-nerving experiences when using Trim Tabs while on the plane.
Was out on Sunday in absolute perfect conditions with 5 adults on board including myself.
Normally go boating single handed so the boat generally felt quite different with the extra load.
On the return journey, just after starting off, using tabs full down to get on the plane then raising them up and accelarating up to about 21/22 knots - all going well.
Then decide to use the tabs independantly to adjust the lateral trim of the boat to allow for the uneven loading of the accompanying crew.
Applied an amount of port tab down a little bit at a time then completely out of the blue and without warning, the boat made an extremely tight turn to starboard which I was unable to steer against and I quickly pulled the power off, by which time we had accomplished a 180 deg turn in about 20 metres!!
The crew then shouted and swore at me while I checked everything out and then we set off again, eventually up onto the plane without a problem - this time without correcting lateral trim and motored for 3 or 4 miles and then a further 6 miles or so later without a further problem. I left the tabs level throughout.
I have since checked the tabs and there is no damage to them.
Advice and comment welcome!
