photodog
Lord High Commander of Upper Broughton and Gunthor
That Isat phone looks like a great deal... cheapest new one I have every seen!
That does look like good value - and the fact that the minutes don't expire (or at least can be rolled over).
If you do go that route I'd be very interested to hear how you get on in W Scotland anchorages.
One slight down on it (for me anyway) is that for some reason the data transfer is far slower that other networks / phones.
From: http://www.satellitephones.co.uk/sales/which-satphone-to-coose/
" iSatPhone PRO supports a 2.4kbps data connection"
"The Iridium 9575 Extreme supports a data connection of 12kbps, or up to 26kbps when used with the optional AccessPoint accessory"
Anyone know why this is - phone ? Network ?
May not matter to you anyway..
Useful tip for folks, Thuraya has roaming arrangements with most major GSM operators. This means that if you place your vodafone SIM in the Thuraya satphone, you can make calls. It will cost you £6.00 per minute, but if its for rare use, backup etc, then its a cheap option in the long run as you would not pay subs to a sat-phone provider. I have not tried this with other satphones though!
Why would you want to do that, given that iridium and Isatphone are around $1 a minute worldwide.?????
Thanks all for clarification on data transmission rates. I'm aware of differences between compressed and raw data rates and agree you should always compare raw rates.
However very interesting to hear that all systems have a max base rate of 2400 (though I did see some suggestion that rates can be slightly faster depending on aerials/atmospherics etc - but it was only slightly)- that's not something I'd picked up from marketing blurb - as you say its always obfuscated by compression rates etc etc. Clearly however you do it - its relatively expensive - but I've found Iridium OK (and useful) for gribs and short emails on occasion - so interesting if ISatPhone will be broadly equivalent - at better rates
