Urgent help required with Raymarine instruments
Bobc
20 Jan 2011
Hi all
Looks like my SPX30 course computer is fried.
My instruments are ST60+ connected by Seatalk 1.
I am trying to get the depth sounder working independently, as the power was from the course computer.
I have got to the point where I have 12v going to a seatalk connector at the instruments, but all the depth wants to do is beep. Nothing on the screen.
What do I need to do in order to get the depth sounder working on its own?
All you need is +VE to the red ST wire and -VE to the bare wire. Easy temp solution would be to disconnect the ST cable and power wire at the SPX, and join them together.
That's what I did. I'm getting 13.2v at the instrument end of the seatalk cable, but all I'm getting from the head unit is a quiet beeping.
If the display is now stand alone, all it needs is power and the transducer connected. Does the transducer connect directly to the display ? Was there a 2nd ST connection at the SPX, if so, where does it go ?
I just temped-up a wire from the fuel gauge light to the positive terminal on the head unit, and it all came alive, so I reckon I've got a problem with lack of amps on the SPX feed, which is maybe why that's not working.
Fingers crossed a temp cable to the SPX will bring everything back online.
Found it. Behind the switch panel, there is a 12v relay for the autopilot. The power output terminal was corroded to buggery. A good clean-up and it's all running again, including the SPX.
Thanks for your help once more Paul.
Bob
Bob
You're welcome Bob, good to hear it's all working again.
