Upper Orwell Crossings update
Burnham Bob
18 Jul 2009
Burnham on Crouch
There is still no information on where and exactly what the new crossing at location A will be. That's the one that could block access to the marinas in Ipswich. However there is a strong lobby to raise the height of the planned crossing to 20-25 metres which would mean most of us wouldn't have to call for a bridge opening.
Crossing C I assume will be an upgraded path across the lock for pedestrians and bikes.
On the website you can see the latest consultation documents
https://www.suffolk.gov.uk/roads-an...nd-transport-planning/upper-orwell-crossings/
However, forumites will be concerned to note that that analysis of the respondents shows that the transgender community is under represented. The religious breakdown of respondents is also included. All of which goes to prove that consultation as local authorities see it is not necessarily connected with the actual issues in hand.
Apparently the project has now been given the go-ahead.
The Chancellor has coughed up £73.4 million to the project. Work due to start in 2019.
Options still in consultation . Competition being held to achieve the best design.
Ben Gummer - he's a good boy :)
Never mind the crossings. Having looked at the animation it seems nearly all the boats have left both Neptune and Haven. Can't be that bad surely.:disgust:
It looks to me as if the budget will not be nearly enough to allow Crossing "A" to be at a height that would allow mast up transit.
For reference, the Orwell Bridge has an air draft of 43 metres. Whilst the "A" bridge would be much lower at 20-25 metres, the ramps for it would take a lot of quite expensive urban land, as opposed to the farmland that was taken for the Orwell Bridge.
After the chaos today when Highways England closed the Orwell Bridge for 12 hours because of "high wind", most people will surely be demanding that money is spent on a Northern By-pass rather than fiddling about with the docks area. A few people might also be interested to hear how Highways England decided that the wind was 80mph, when there was nothing like that that at Felixstowe.
HWE have to judtify the £ zillions spent on those A14 matrix signs ( 3 miles to Junc ???? 38 mins to BsE )
