Karnic
Currently using an aluminium prop 3 x 14 x 19. No issues. Wish to upgrade to a stainless steel one would it have to have same measurements or? If not what dimensions do you recommend?
Also i noticed that outboard was rigged with a few millimeters ( 5/7) of inclement to port side. While smoking a fag and having a cup of tea at garage noticed that OB is very slightly inclined to one side. As boat is jacked i imagined that is the reason,but while examining it carefully and took the measurements i noticed that there is a very slight inclement to one side. As stated not more than 7 mm. Would this issue is a reason for concern? As i bought this new OB from a certified dealer what should i do? Holes on new boat were also done by the man that rigged the OB. What are your Views?
Appreciate your kind help.
