Stemar
In another thread, that I don't want to hijack, there was a link to Smartgauge.co.uk, which is full of interesting stuff. Wandering around the site, I found this way to improve charging rate. It's rather tempting to do as I have an older type alternator.
Any comments from any of the resident experts?
My alternator has a connection which allows me to unplug a wire from the B+ terminal and connect it to the battery + to make the alternator battery sensed. There's no advantage to doing that, because I use a split charge relay and have negligible voltage drop, but it seems that that's going to be the rotor supply, so putting the diodes between D+ and the wire would be a good thing to do. Is this correct?
For a 65amp alternator, are the 10amp diodes suggested likely to be OK? SOmething like this?
Finally, why, as suggested in the artilce, should I consider Shottky diodes - wouldn't I need 2 in series to get the same voltage drop?
Thanks in advance.
Thanks in advance.
