sarabande
A recent event on the Tamar may provide the OP with some help.
About 6 weeks ago, just after the September full moon (springs) I was on the Tamar talking with a moorings contractor of very high reputation. He was busy solving a problem he had not experienced in more than 30 years work.
A partly sunken tree, probably about 3 tons mass, had tangled itself round the riser from large concrete sinker on a fore and aft mooring. The pressure of the tidal ebb (about 4 kts) had moved the sinker, then broken the riser, leaving a 20 ton sailing boat moored by the stern.
Now knowing that the OP is on a tropical river, I could make a case for a similar event with a sunken object lifting the chain and the anchor, and then rolling away, dumping the anchor in the main stream, where it then reset itself.
Are there any signs of damage to the anchor ? That might give a clue to what has happened. It would need a large force to lift the anchor vertically, but it happened to a mooring here in Plymouth recently.
With two decent anchors on the OP's boat, it is hard to see how an anchor can move, after being dug in, except by an external force. And no amount of experience or forethought can counter that.
