ss2016
I have a VP D6 with a DPI stern drive. After some 16 months in the water the anode above the cooling outlet on the drive leg is significantly depleted and needed replacing, while the anode at the bottom of the transom shield is almost as new. Is this normal?
Is the reason that since VP painted everything there is very little exposure of unprotected metal to the water except the propeller which the depleted anode has protected?
Interestingly the anodes on the SS trim tabs are also eroded significantly. Is this because the antifouling has not bonded well and they present a significant surface area?
Thanks, Steve.
Thanks, Steve.
