Ed Sned
Active Member
NKE is good, albeit the user interface is pretty clunky. The Figaro 3's all use it, as do many of the Class40s, and many of the older Imocas. The newer large-foil boats are mostly using Madintec now though.
It's a bit fickle to set up - or can be. However, once it's up, and all the components can be seen on the topline, then it's pretty robust. There are a lot of settings though, and you end up with a laminated matrix for the different conditions - hence a change in course or conditions requires 10 mins retrimming and checking all the sails, followed by 10 mins "trimming" the autopilot. It's not for everyone, I appreciate.
