ugh, now it leaks after the DPE has been put back on
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
i have a camera in the engine room, paid off several times so far
engine compartment was bone dry before the DPE removed and put back on again
checked the bilge water, it is salty, and collecting in the centre of the engine room bilge
this is only happening when going in reverse, checked it 2x on the water
def comming from the aft end of the kad and from the centre
not green, and not comming from the sides
had it on the trailer just now, took a camera screen shot of the bilge with a small amount of water already in from the reversing when out on the water
put the hose on the DPE, below the helmet only, another screen shot and the water level increased further
so, likely something has not been put back quite right, any ideas ?
Steering g helmet shaft seal dried up , try greasing the steering arm , there is a nipple on it to grease the steering shaft .
