richarda
My boat has a system in which the hoses from both the electric and manual bilge pumps exit through a single skin fitting. While the philosophy is right the plumbing is crude, joining two different size hoses through a modified T piece close to the skin fitting. I am concerned that it has been installed without any real understanding of how the water moves when either pump is activated. Although some water goes over the side it looks to me as if the water from one can simply flow back down the other hose once pump pressure starts to reduce.
Is there a straightforward and agreed way to run the hose from the electric bilge pump (3/4" outlet)and the manual pump (11/2"outlet) through the same skin fitting without backflow or air lock problems?
