Tim Good
Also I would replace the spare yankee with the genoa
But then that defeats the abject of the twistle doesn't it? If you have thistle with a yankee on one side and a genoa on the other it would be unbalanced no?
Not really. I've done twin headsails with all combinations of jibs, Yankees and genoas and with a bit of trim the balance is fine.But then that defeats the abject of the twistle doesn't it? If you have thistle with a yankee on one side and a genoa on the other it would be unbalanced no?
Twistle rigs have custom made made sails and poles for the size and weight of boat. A mix and match would be an unbalanced disaster, so yes you are right.
Another thought for the OP: I said we carried a spinnmaker but never used it, it was left on the boat by the previous owner . In hindsight we should have left it behind. If you do that you will have more for space for a genoa which to me is a critical sail.
>Is that based off your experience of trying it and it didn't work or just a guess? Different people sail in different ways. We would never dream of leaving our spinnaker behind. Unthinkable.
I was talking about long distance sailing if you have a Twistle rig there is no point in carrying a spinnaker. You can reef an twistle rig but not a spinnaker it's either up or down subject to wind strength. I aslo mentioned long distance sailors take the spinnaker down at night and use a poled out foresail and a preventer on the boom, which significntly increases rolling as the foresail pushes the mast and vice versa.
If day sailing and holiday sailing I see the advantage of having a spinnaker.
Try this trade wind rig:
Main and genoa set wing and wing as per normal.
On your removable inner forestay set your heavy weather jib and sheet it hard to leeward ie; the same side as the mainsail.
You'll find that the boat stops rolling her brains out, tracks straight and makes good speed. If the wind picks up it is a simple matter to roll the genoa a bit.
I'd take the spinnaker and leave the twistle rig stuff behind.
