twist in the main sail ?
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
the top part of the main is supposed to twist at low to medium wind speeds, sugesting that higher up the wind direction is further aft
but the wind speed is supposed to be greater further up as there is less drag from the water surface, so that would suggesd no twist at all ?????
please, someone explain this to me
Assume you're sailing upwind. The wind onto the sail is made up of the true wind, plus the effect of the boat's speed through the water. This Apparent wind is further forward than the true wind.
At the top of the sail, the true wind will be a little stronger, but the boat speed is the same (obvoiusly) so the apparent wind is not so far forward.
That's the theory.
also the effect of swell means the top part of the sail oscillates through the wind more than the bottom part. Having twist means the top part of the sail doesn't stall when the boat rolls into the wind direction. Anyway it seems to work in practice
No-one's mentioned the most important factor yet: your foresail.
This has the effect of creating a slot between the foresail leach and the mainsail luff. Since air is accelerated through the slot, the pressure is lowered even further than just a single sail and Mr Bernouli pulls your boat foreward. The foresail is far wider at the foot and therefore has a far greater effect of directing air over the main.
