twin fuel filters
Thanks for the PIC...does the fuel supply come in from the right of the PIC? I want to make my own set up.
No it comes in on the left & out on the right. There are in & out ports on both sides of the filters so you can make it up how you want (arrows can just be seen if you zoom in).
Do buy a pipe bender to make life easier, Ebay has them & don't forget sealant on the joints.
Thanks, I will, one question... Sorry if its a silly one but I notice the two filters are connected, doesn't that defeat the object of have a separate system, I can't figure out how you would isolated the blocked filter.
Not at all silly, the valves are called "L Port" & switch one input port to either output port. Which ever filter is not in use is totally isolated.
You must of course operate both valves together or it could be a bit embarrassing when the engine goes quiet:encouragement: I mounted my valves so the levers always point the same way to avoid any errors.
Thanks, that makes sense.
