Turbo36 fuse
  • Start date Start date
G
Guest
Guest
I own a Fairline 1982 Turbo 36 and whilst I know that most of the fuses are behind the panel in the forward heads, I cannot locate the fuse for the Trimtabs. Can anyone help, please?
The chances are that this fuse is shared by other electrical items, as it is an early boat, trace from rocker switches if you can as there wil be only an earth wire probably black to an earth busbar, or brass strip, live may be red.
Does the panel have trips or actual separate fuses I wonder, take each fuse out in turn untill the tabs stop working, there may only be an inline fuse near the pump motor also.
Paul js.
