Tube stack
mick
10 Aug 2001
Clyde
I've just removed the heat exchanger tube stack from my one-year-old Beta 13.5 in order to clean it. The tubes were fairly clear but I cleaned them by pushing through a thin wooden skewer. Do I do anything else?
You could put some limescale remover through it to get any calcium out, but as the man says, put it back in, test it for leaks and go out sailing/boating, whatever!
The tubes ought to be clear as it's the engine coolant that should be passing through them, not salt-water (you do use anti-freeze with anti-corrosion addatives in the engoine, don't you?). With the stack removed you should be able to examine the outside surface of the tubes for crud, corrosion and/or cracks (dye penetrant examination). This latter is only necessary if you think the tubes look really bad and then you'd probably be happier with a new stack anyway.
I wouldn't use an "oxygen" cleaner on the tubes (Cillit Bang or the Flash cleaner that removes rust stains for example) You never know what they're doing to the alloying element of the tubestack) but washing them down with limelite and thoroughly rinsing ocasionally is a good move
In my Beta 13.5 it's salt water that passes through the tube stack. Some of the tubes were partially blocked by pasty bits from the anode, which had disintegrated.
