PetiteFleur
Fitted a Trudesign heads outlet with valve etc. Asked the boatyard when launched to check there were no leaks. Was told they have problems with 'frost' - is there any truth to this? They had not heard of Trudesign.
That's absolute nonsense. How can they have problems with frost on fittings below the waterline ?Fitted a Trudesign heads outlet with valve etc. Asked the boatyard when launched to check there were no leaks. Was told they have problems with 'frost' - is there any truth to this? They had not heard of Trudesign.
I can't see swelling wood splitting them. They are way stronger than that. Sounds like someone who doesn't understand composite materials making up a wives tale to me.Only caveat with Trudesign was to remove any wooden backing pads which a surveyor advised can swell if wet and split the fitting.
Forespar say :Only caveat with Trudesign was to remove any wooden backing pads which a surveyor advised can swell if wet and split the fitting.
Can't remember which one it was but I have a vague memory that it might have come from the USA
Not TruDesign then as they do not come from USA.
