Peter
Thanks for your answers to my previous post, just looking for a final option before I make my final choice against Trogan's, or leisure battries based on some answers I have received off Trojan. For info my set up is repeated below. My biggest question is the mixing of the Trogan's 12v and 6v batteries where I need the 12v to provide cranking current to my bow thruster/windlass
TROJAN ANSWERS
In parallel connections, different amp-hour capacity batteries can be mixed but do not mix different battery chemistries or manufacturers. I recommend you use the SCS225 as your 12V battery to mix with T-105’s in parallel.
The 820A cranking rate is at 32 degrees-F and it is for 30 seconds. This battery is a deep cycle battery first, and can be also used as a cranking battery.
The cycle life for the SCS 225 is 600 cycles at 50% DOD and 1200 cycles for the T-105 at 50% DOD.
The 12V battery should have no effect on the T105 batteries when it comes to cycle life.
Current set up 440amp/hr house battery’ bank, seperate up front battery 110a/hr for bowthruster and windlass, but connected to house bank, so seen as part of house bank, and engine start battery with VSR separating house and engine battery. All charging by solar, wind and shore based Stirling battery charger.
TROJAN ANSWERS
