Trim Tabs
I am thinking about adding trim tabs to a similar boat. Picture shows her at 10 knots. Flattens a little at fast cruise pace. Are they effective on this type of boat ie semi-displacement? Would love to know of others who have seen an improvement....
10 knots is just a wrong speed for that boat. You need to be doing 6-7 knots, or planing.
I agree about the speed not being ideal but she does not rise up onto the plane, ie over the hump and flatten out, making me think she is semi-displacement. Even at full tilt she runs very nose up. How can i tell what type of hull she is as I have seen it described, semi-displacement and semi planing?
Apologies in advance for fred drift but I made a discovery a couple of weeks ago in connection with trim tabs on my semi-d vessel which made me both blush and laugh.
What I discovered was that you need to press and hold down the buttons (bennett), not just click them like a keyboard button.
I've only had this boat for three years... :o
And, yes, I reckon I did get an extra knot and that the angle of attack was improved, but the difference wasn't mega.
My last boat reacted much faster to a small adjustment via the tabs, in fact needed trimming fairly actively.
Know someone who runs an Antares 9, similar boat and he cruises everywhere at about 14 knots using no fuel at all with a single D4, so doubt you could call them a true planning hull, if it was you would be squarely on the hump and using tons.
If I am not mistaken they also have a decent run of keel which helps with the leaning into the wind issue.
He has tabs but says he very rarely touches them as they make no difference to the ride.
I'm pretty sure you hull is semi displacement (semi planing means the same thing), rather than full planing.
At 10 knots you're not on the plane, but you are exceeding the displacement speed. Your bow will be high, the stern will be in a hole and the water at the back will look like a cauldron. Now, ease off the throttle a little at a time, as you do so your speed will drop slowly, the engine RPM will drop faster. When you reach maximum "sensible" displacement speed, the water at the back will stop churning, the bow will lower and the boat will level out, the engine RPM will be hugely lower, but the speed will only be slightly lower and everything will be much quieter, your fuel bill will be vastly lower. When on the plane, the bow will sit about the same as in the OP's pic.
First of all, looking at your picture, she looks like running at an OK angle, but that can of course be deceiving.
Now on to a couple of "IF's"....
1) If she is running on shaft(s) that are angled
2) If pushing bow down does not increase friction significantly (always a risk)
... then theoretically you could achieve a slightly higher speed for two reasons..
a) you will present a slightly larger waterline length, which theoretically should mean higher hull speed.
b) the propellor will direct waterflow more directly astern (rather than downwards), should theortically mean greater propulsion efficiency, and thus higher speed (or lower fuel consumption for given speed).
Now there are a couple of issues you need to be aware of...
1) You ought to be able of running as if the flaps were not there.. (see 2 below)
2) In following seas your possilbe lift surface (for the sea) is greater, so she may change behaviour in following seas. 1 above will minimise this, but will not eliminate the risk.
Mariek -Wot is 25 knots (with clean bottom) fast cruise is 18-20 at 3000rpm. Paul -thanks for explanation about wake etc. I come from a planing hull background so this semi-d is all a bit new! It sounds like I won't gain much from tabs. Fuel economy is good and she feels planted in all sea types. Only option is to give it more welly!
More welly is always good :)
