kennyh
I don't disagree that certain boats may have had the tabs installed the "wrong" way.
I've used tabs on a number of boats, and fitted tabs on one boat also.
On my current "stock" install of Volvo tabs, the port button lowers the starboard tab.
And the following from Bennetts (one of the leading Trim Tab manufacturer) says in their User Manual:
"CorreCTinG For a lisT
Bennett Trim Tabs may be operated individually so that you can correct for listing. Your control is designed so that you can use it “intuitively.” Do not think about what the trim tabs are doing, just concentrate on the bow. If the port bow is high, push the port side “Bow Down” direction. If the starboard bow is high, push the starboard side “Bow Down” direction. Press the control in half-second bursts to avoid over-trimming, allowing time between corrections for the boat to react."
On the Bennetts tabs, pressing Port Down button lowers Starboard tab.
But clearly, from the comments on this thread, not all boats/setups are the same.
