Trident Voyager
Is the Trident Voyager a deck saloon version of the Warrior? If you know the answer please reply
Mike
tomg
North Bucks
The Voyager is the deck saloon version of the Warrior, same hull, but different internal layout. Rig is usualy the same cutter arrangement but it specifies two engines, typically 30/35 Hp each instead of the single 50HP in the Warrior. It is significantly more expensive than its sister.
davidt
30 Nov 2004
I have a Trident Voyager 35. She has the same hull as the Warrior 35 and, indeed, the Challenger 35. The three models share the same hull but have a different deck moulding. The Voyager is the Deck Saloon model, The Warrior is a centre cockpit and the Challenger an aft cockpit. (I may have got those two the wrong way round!) All three are mast-head rigged sloops.
