Tree attacks dinghy
Grehan
11 Jun 2001
Inland France + Oxon.
www.french-waterways.com
The big willow next door suffered badly in the recent strong winds.
Good News : our cars weren't parked underneath like they normally are.
Bad News : our ply Mirror dinghy was. Branch plummeted earthwards, through the vinyl rain cover, through the ply hull 'bout half way between mast and shrouds, and hit the dirt.
Result : a three inch diameter hole.
Their property insurers say they aren't covered, and so does ours.
So I've got to get it mended well, but cheaply (can't / don't want to do it myself).
Any suggestions?
[Oxford area or within striking distance of]
Many thanks
I'm in the phonebooth. It's the one across the Hall
BrendanS
11 Jun 2002
Tesla in Space
Re: Your neighbours are liable
"if the fence or hedge falls over and causes damage to a neighbour's property your neighbour will be liable to pay for any damage"
<A target="_blank" HREF=http://www.bbc.co.uk/watchdog/guides_to/gardeninglaw/+neighbour+damage+tree+uk+law&hl=en&ie=UTF-8>http://www.bbc.co.uk/watchdog/guides_to/gardeninglaw/+neighbour+damage+tree+uk+law&hl=en&ie=UTF-8</A>
Mirelle
N/A
30 Nov 2002
Invisible mend?
You need a patch scarphed into the panel. Not hard to do - cut back from the edges of the hole so that it it is tidy and square shaped. Then mark a square round the hole such that the distance from outside edge of square to hole itself is at least 8 times the thickness of the plywood.
With a very sharp, wide, chisel, cut back from the outer to the inner square at an 8:1 gradient. This is easier than it sounds because the laminates in the ply help you by showing you the "contours".
With an equally sharp plane, on a bench, bevel the edges of a square of ply which is very slightly larger than the square recess in the boat's panel. Do a few trial fits.
Mix up some epoxy and unite the two, using weights on the patch with the boat inverted to ensure contact - or use a strongback and a thin bolt through a hole which you subsequently fill with epoxy.
If you dont fancy doing this yourself, Bossoms would seem to be the people in Oxford...
