Has a similar effect as letting out the mainsheet - de-powers the main a bit so the boat sits up. If you are heeling too much then you need less sail or less power in the main by letting it to leeward one way or the other.
No doubt there are theorist out there with a more complicated view of it!
Also gives more precise control of the sail through main sheet by keeping the latter shorter, in other words the more vertical the main sheet the more precise the control, less lost time and motion.
BTW have you ever sailed around Dunmore east? stayed there once, "Still Gods country."
Reducing mainsheet tension allows the leech to drop down but also increases sail curvature, thus overall effectiveness is not the best. The upper part of the sail remains fairly close-winded, having little effect on heeling.
Dropping the traveller down a little allows the sail to remain flattter but overall less close-hauled, so heeling is reduced but power stays up.
I have NEVER found any value in my boat from hauling the traveller to windward. I always end up either stalling the main or having to let it back out again to maintain drive.
Is this something typical of AWBs or am I just not doing it right?
traveller to windward with sheet eased to keep boom at centreline (and with Kicker slack) will give a powerful twisted sail but still on the centreline.
Pops
[/ QUOTE ]For light airs haul the traveller up and let the sheet go to centre the boom, the top of the main will ease, the kicker will have a lot of control.
So I get that the traveller to leeward keeps sail , boom and sheet in same vertical plane and so prevents sail twist.
But why is a sail which can twist more powerful than a rigid sail? I would have thought that a sail capable of twisting could spill wind in a gust and so heel less. /forums/images/graemlins/confused.gif
The wind near the water is slowed down by friction. Allowing the sail to twist (a bit) will set the sail to the correct angle to the wind at different apparent speeds (and hence angle). The effect is even more pronounced with a fractional rig, where the jib bends the wind around the lower part of the mainsail.
