jeffsnox
New Member
Transom Outboard Bracket for Outboard Storage and Aux Engine?
Is a transom mounted outboard bracket a suitable way to store your
dinghy outboard? I mean one of the hinging types.
If fitted correctly, would that not also be useful as an auxiliary
engine in case of a problem with the main inboard?
If that's a good solution, couple of questions:
1. Would it be worth bothering with a 2.5HP outboard? Or would that
not even give you 1 knot, down hill, with the wind behind you? What
would be a minimum useful outboard power then?
2. Any specific requirements for the bracket? Any recommended make/model?
3. How complex a job is it to fit one? Would I need to get a metal
plate machined up to go inside the boat to bolt through into?
Thanks,
Jeff
Thanks,
Jeff
