Blue_Blazes
I've just changed the Borg Warner gearbox on the rebuilt Sabre 180 I'm going to put in my Christina 23. The engine came with an old 1.5:1 reduction box. I managed to get hold of a brand new 1:1 box, which is the correct ratio, to replace it. I removed the old box along with it's associated heat exchanger, so it's still full of Automatic Transmission Fluid. The fluid will have to be drained off when I remove the heat exchanger to fit it to the new box. The new box has no fluid in it yet.
Is it ok to use the fluid from the old box to fill the new one or should I get new?
