retsina
You will be able to tow the Macwester if you have a very good trailer with good brakes, preferebly flat bed for lower centre of gravity. My landrover discovery can easily pull this load on the road; BUT the road must be flat, uphill not too bad, downhill you have to be very careful. The problem is that the boat plus trailer will be heavier that the tow car which means that the tow car is not in full control; you are controlled by the weight behind you. For a short distance very early morning its ok.
