Trailer query
grantdean
New Member
7 Oct 2018
Evening all. I have an opportunity to buy a 27ft twin axle de graaf trailer. The info plate says complete permitted load c+s 1600kgs. Then upto 3000kgs. Would this be suitable to load a 2880kg dry weight boat? Thanks
I am tempted to suggest that 1600kg is the max individual axle load and that 3000kg is the max gross weight
If 3000kg is the max gross weight then it will not be suitable for a load weighing 2880 kg
Although not so sure what the 1600kg refers to I would expect the largest number on the plate to be the max gross weight
You quote the dry weight of the boat, might be an idea to find the actual weight. Sounds like the gross weight is 3000kg, The trailer weight will be on the plate and it likely to more than the difference between your boat and the gross.
