trailer parts suppliers?
aztec
10 Oct 2001
Poole Dorset
hi, just considering my options..
anyone know of trade suppliers for small trailer parts?
what i'm after is suspension, fittings, hitches and hardware... all cheap (naturally) i need another trailer, needs to be multi purpose.. and fold away, to take small boats and able to take 8 x 4 sheets of ply etc. and fold away so as to be store in a large matchbox!!
not much to ask but..... anyone??
cheers, steve.
Jools_of_Top_Cat
16 Dec 2002
<A target="_blank" HREF=http://www.towsure.co.uk/>http://www.towsure.co.uk/</A>
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk>Top Cat Homepage</A>
Avocet
3 Jun 2001
Cumbria
Indespension are quite expensive compared to Towsure (last time I looked anyway) but their stuff is good quality.
Avocet
3 Jun 2001
Cumbria
...and if you want REALLY cheap and don't mind getting grubby, look for a caravan breaker - I think there used to be one round Liverpool, try an internet search.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
<A target="_blank" HREF=http://www.cruickshank-trailers.co.uk/>Cruickshank Trailers</A>
52a Hermitage Street
Crewkerne
TA18 8ET
0146013469
Davy_S
31 Jan 2003
in limbo at the mo.
If you are building a trailer to last, then indispension are not cheap but far superior to Towsure products. Towsure are cheap for one reason only, their stuff is CRAP.
me2
19 Dec 2003
poole
Try any trailer outlet that sales Peak trailer parts they are a lot better and cheaper
jleaworthy
20 May 2002
Essex
Over the past thirty years have built a number of trailers from small baggage trailers to 1 tonne boat trailers. Initially used Indispension (their book of plans was invaluable) but for the last fifteen years or so have used Towsure for both towbars and trailer parts mainly because of their price. I have never had any problems with either Indispension or Towsure components and I find it difficult to understand how anyone can describe the latter as "crap".
Davy_S
31 Jan 2003
in limbo at the mo.
Well I agree I probably sounded a little over the top with my choice of words. The reason is that on our coastline ther are over 300 small cuddy type fishing?sports boats belonging to three main clubs, all are launched by tractor or 4 wheel drive directly from the beach. As you can imagine this causes untold problems with trailers Usualy the rollers and support rollers are the first to break, now if you compare a roller bracket from towsure to one from indespension you will see for yourself that the indespension bracket is thicker metal and far more able to withstand abuse as described. Put simply the towsure brackets collapse after hard use and the rollers do not turn. If you do not agree then simply compare them side by side and you will be surprised at the difference. I think this is one case of you DO get what you pay for. AS for their other products they may be ok, Their towbars are good value for money IMHO you pays yor money and takes your chance /forums/images/icons/smile.gif
me2
19 Dec 2003
poole
In Dorset try Ambrow trailers in Christchurch,Eagle trailers in Poole and T.T.C Engineering in Poole they all offer good makes of units ect
Avocet
3 Jun 2001
Cumbria
I bought a pair of suspension units from Towsure about 7 or 8 years ago. I already had a couple of Indespension ones on the trailer to compare them with but didn't fancy paying out for another two genuine Indespension ones. The main difference was that the Indespension units had a nylon bearing in each end and the rubber elements in between. I couldn't see a bearing on the Towsure ones - they just seemed to rely on the rubber and a steel endcap with a hole in it welded on to the outboard end of the square tube. Both units were on one twin-axled trailer so I had a good chance to compare them. Within a few weeks, the wheels on the Towsure ones had develped visible negative camber and I could see faint "witness" lines where the moving part of the axle was rubbing against the steel end plate. The Indespension ones were fine. When making a tight turn, the tyres on the Towsure units would visibly displace the axle in its housing and then "jump" sideways across the tarmac whereas the Indespension units remianed much better located. In fairness to Towsure, their units didn't actually fail and they were a LOT cheaper than the Indespension ones but the difference in quality was very obvious.
aztec
10 Oct 2001
Poole Dorset
thanks for that... yep i'm onto TTC at the moment.
still might be cheaper and easier to buy a second hand one and convert it.
regards, steve.
me2
19 Dec 2003
poole
As i said before ask for Peak units there are no bearings in units all are made the same its just an end cap you can see all use rudder but Peak us solid arms so dont bend like the hollow ones
