tp20 help
gd7hej
11 Jan 2002
isle of man
hi,fitted tp20 autopilot to my trapper,but cannot get it to calibrate,had it in the right mode with both p/s leds on,going round in a circle tried about 100 times,still will not calibrate.???also i have tried to use it in auto mode aimed boat for a headland the boat wanders upto about thirty degrees either side,tried altering both sea state setting and gain to no avail,after about 2 mins,it stops working and she sends a continous bleep,any ideas from a very dizzie graham....
beneteau_305_553
1 Apr 2002
Norfolk UK
I have had similar problems with my tp 10.
The first went brain dead in June last year, within 6 weeks from new, the spare then failed at the start of this season after about 20 hours use and the warranty repaired first is now playing up: I cannot change the sea state or gain setting, so it will go back when i get the repaired second one back!
anyone else having problems?
<hr width=100% size=1>Richard
cindersailor
30 Jan 2003
Edinburgh
My TP 30 has an intermitent fault where it cuts out, beeps and goes into standby mode. It is entirely random; some days not at all, others just a couple of times and sometimes every few minutes. When it cuts out it clearly sends a spike through the 12 V system as the GPS turns itself of and the VHF crackles. I will need to send it back to have it cheked out at the end of the season, but in the meantime has anyone else had a similar problem?
