Towing
zoidberg
12 Nov 2016
....and being towed.
Lifeboat tow
Two of the current crop of 'Jesterers' have been in a towing relationship for some days, down south near the Azores. I find myself wondering which of my fellow yotties have the knowhow to effect a successful tow in even moderate seas. Equally, whether deck fittings - front and rear - are robust enough for such a task.
This was an ordinary, if not everyday, skillset in the olden days before GMDSS and Surestart. Hands up those who know they could manage.....
doris
19 Jun 2001
London
Definitely need a bridle , both ends , to spread the load. If the mast is keel stepped should be included in the front bridle, if not include winches.
All winches available should be included in the aft bridle.
Think how long a rope is needed , then add some, with some chain in the middle if possible.
slow is good.
Daydream believer
6 Oct 2012
Southminster, essex
My insurance policy bans towing unless an emergency. i have towed a friend out of the Dover Strait shipping lane when he broke down & there was zero wind to sail. I felt that was an emergency & he was insured with the same company.However, when we arrived at Boulogne I was able to hand the tow to another boat as I declined the request to take him right in. I did take his lines on arrival though ;)
I took a strop to both aft cleats with supports to the winches. The tow was quite long. Unfortunately I did NOT have a day shapes to indicate my limited manouverability.
I do a lot of towing in our mooring area when I place moorings with my launch. The day shape is always hoisted. That being said I am sure some yachts seem oblivious to its purpose. the launch is fitted with a purpose made towing stand in the centre 5 ft in from the stern.
WGWarburton
9 Apr 2019
I'd see this as routine, unless the weather indicated otherwise, as with most things sailing...
We came across a motor-cruiser that had run out of fuel off Cove last season- rigged a bridle to the primary winches and put a block on the towline to allow the pull to move. Turned out they were heading to the same place as we were, so dropped him off at a pontoon on arrival.
Cheers,
W.
Gary Fox
N/A
31 Oct 2020
Make sure the line is long enough, longer is better.
We snapped off this hook, a clean break, due to a too-short wire!
(If you look closely, you can see the welded repair just in front of vertical pin)
(If anyone is interested, the Tug is Sheen, built Lowestoft 1927. She is in retirement but still floats and runs.)
DFL1010
7 Sep 2011
The tow was quite long. Unfortunately I did NOT have a cylinder to indicate my limited manouverability.
I do a lot of towing in our mooring area when I place moorings with my launch. The cylinder is always hoisted. That being said I am sure some yachts seem oblivious to its purpose.
Err, hate to say it, but...
Cylinder is for constrained by draught. Ball diamond ball for RAM (which one may be whilst towing, but not necessarily). Diamonds for towing (if over 200m).
Daydream believer
6 Oct 2012
Southminster, essex
Sorry.o_O I meant day shapes but we have a problem getting the complete bit in the heightof the mast so it is a bit dubious . Actually due to our length we do not actually need it but we do have the odd issue if we leave the tow a bit long & are out in the river with boats tacking astern of us. Arm waving sometimes needed. but I am not sure which part of the colregs that is, other than "help" which is not the intention. :unsure:
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
Watching that video made me realize just how bad being towed could be. The video stopped before the strain came back on the line, but the towed boat had sheared off nearly broadside to the tow after surfing down a wave. I was waiting for an almighty jerk when the strain came back on. You can see why towing lines break so easily.
penfold
25 Aug 2003
On the Clyde
Perhaps a drogue would help, although balancing the need to slow or inhibit surfing with not placing an intolerable strain on the tow would be tricky.
Caraway
11 Aug 2019
England
Was Greta on board?
Gary Fox
N/A
31 Oct 2020
A long heavy tow line means that when the tow surfs down the wave, it doesn't overtake. In theory anyway..
Slowboat35
4 Apr 2020
It looks to me as though the yacht in that video was being towed at a ludicrously excessive speed, something the RNLI seems to be renowned for. I've seen several videos of them towing sailing yachts at uttely insane speeds.
I don't think a long open water tow is likely to be a feasable option between most leisure yachts as none of us carry lines anywhere near long enough for the job. A short tow will soon develop a failure somewhere due to snatch-loads. As for towing into harbour, a line astern tow is not the right way as it leaves the towed vessel out of control with any manoeuvering - it cannot ever place the vessel safely in a berth or even alongside. (It might save life - but its a messy way to get a stricken vessel the last bit home). Transferring to an alongside tow is the seamanlike and not difficult way to put the victim on a quay or mooring.
Gary Fox
N/A
31 Oct 2020
^^ I can vouch for the RNLI, or a certain cox'n to be fair, towing at dangerously high speed. I was on the yacht.
There was no hurry, yet the back of the yacht was almost submerged, the boat was shaking and shuddering.
Despite repeated acknowleged requests, he wouldn't knock it back, even a knot. No they didn't have another shout to attend.
He had a big ego problem, even RNLI volunteers can be total and utter d1ckheads occasionally.
penfold
25 Aug 2003
On the Clyde
I'd put a knife through their warp and take my chances before putting up with dangerous nonsense like that.
Gary Fox
N/A
31 Oct 2020
I'd put a knife through their warp and take my chances before putting up with nonsense like that.
It was only for a mile before we arrived and tied up, or I would have done, and I actually had my knife ready and mentally planned my subsequent actions.
penfold
25 Aug 2003
On the Clyde
It must be some form of machismo; towing puts strains on boats that they are not designed for and they want to impose more strain than is needed and exacerbate the instability by towing beyond hull speed?
zoidberg
12 Nov 2016
The two 'Jester' boats MINKE and GOOD REPORT are at the moment in a Tow/Towing configuration, and have been for several hundred miles. At present they have around 150nm to go.
Details are sparse, for obvious reasons, but it seems MINKE lost her rudder some days ago, GOOD REPORT came to 'stand by', and this towing exercise was the option they've settled on.
Gary Fox
N/A
31 Oct 2020
I usually have 100m -ish of 12mm on board my yacht, for eventualities, but it would not be rapidly accessible. Stowage for stuff like that is such a compromise and coin-toss; if you put the things you think you will need need at the top...
You can use a weight in the middle, someone above mentioned chain.
I wouldn't mind knowing what a suitable middle weight would be, for two cruising yachts and 100m towline. 10Kg? 20Kg? Total guess.
